Crazyradio PA PPM Input
4things
Post by 4things »
I need help connecting my Taranis to Crazyflie Bolt deck.
I figured out that the Crazyradio PA got an PPM Input what is described in this article:
https://www.bitcraze.io/2012/04/control ... rc-remote/
could you please tell me how to hook it up?
thank you in advance
4things
Re: Crazyradio PA PPM Input
If the Teranis reciever has a CPPM output (Combined PPM) you can connect that signal to the BQ-deck CPPM input and GND->GND.
4things
Post by 4things »
Thanks for your reply. I want to connect ppm to Crazyradio PA to avoid using bigquad deck. I have a bolt fc with flow deck. The cppm input pin collides with cs pin of flow deck.
Have you any instructions how to use the Crazyradio PA with PPM input?
Thanks a lot in advance
No, sorry
The answer in your other thread will hopefully solve it.
