cant compile QC FW scripts
RyanQCFlyer
Post by RyanQCFlyer »
im runing ubuntu 14.04 and i get this
ryan@ryan-desktop:~/projects/crazyflie-firmware$ make CLOAD=1 DEBUG=0  CLEAN_VERSION
  CC    list.o
make: arm-none-eabi-gcc: Command not found
make: *** [list.o] Error 127
i have tryed this http://forum.bitcraze.se/viewtopic.php?f=6&t=378 with no luck. i cant get it to work. plez help.
Re: cant compile QC FW scripts
Seems that you do not have gcc in the path. I assume you already downloaded and decompressed arm-none-eabi- somewhere. You can try to type this before trying to make:
export PATH=<path-where-you-decompressed-arm-none-eabi>/bin:$PATH
Replacing <...> by the path where you decompressed gcc. Then to always get gcc in the PATH add the line at the end of the ~/.profile file
Another solution is to use the ubuntu-provided compiler with:
sudo apt-get install gcc-arm-none-eabi
It should be in the path automatically and work out of the box but we did not test this compiler very much.
RyanQCFlyer
good news it sarted to work but i got this at the end
this is were i put the gcc
/home/ryan/bin/gcc-arm-none-eabi
but i downloaded the ubuntu one you gave me. and it did this
  CLEAN_VERSION
  CC    list.o
  CC    tasks.o
  CC    queue.o
  CC    timers.o
  CC    heap_4.o
  CC    port.o
  CC    misc.o
  CC    stm32f10x_adc.o
  CC    stm32f10x_dbgmcu.o
  CC    stm32f10x_dma.o
  CC    stm32f10x_exti.o
  CC    stm32f10x_flash.o
  CC    stm32f10x_gpio.o
  CC    stm32f10x_i2c.o
  CC    stm32f10x_iwdg.o
  CC    stm32f10x_rcc.o
  CC    stm32f10x_spi.o
  CC    stm32f10x_tim.o
  CC    stm32f10x_usart.o
  CC    main.o
  CC    led.o
  CC    uart.o
  CC    adc.o
  CC    nrf24l01.o
  CC    exti.o
  CC    nvic.o
  CC    motors.o
  CC    mpu6050.o
  CC    i2cdev.o
  CC    i2croutines.o
  CC    hmc5883l.o
  CC    ms5611.o
  CC    crtp.o
  CC    ledseq.o
  CC    freeRTOSdebug.o
  CC    imu.o
  CC    pm.o
  CC    radiolink.o
  CC    eskylink.o
  CC    usec_time.o
  CC    system.o
  CC    comm.o
  CC    console.o
  CC    pid.o
  CC    crtpservice.o
  CC    param.o
  CC    commander.o
  CC    controller.o
  CC    sensfusion6.o
  CC    stabilizer.o
  CC    log.o
  CC    worker.o
  CC    filter.o
  CC    cpuid.o
  CC    cfassert.o
  CC    configblock.o
  CC    eprintf.o
  CC    crc.o
  CC    fp16.o
  CC    debug.o
  CC    abort.o
  VTMPL version.c
  File "scripts/versionTemplate.py", line 23, in <module>
    revision = subprocess.check_output(["git", "rev-parse", "HEAD"]).strip()
  File "/usr/lib/python2.7/subprocess.py", line 566, in check_output
    process = Popen(stdout=PIPE, *popenargs, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
make: *** [version.c] Error 1
Looks like you do not have git installed? You can install it with "sudo apt-get install git".
RyanQCFlyer
thank you so much. im new to this and you have really helped me set this up. :D :D :D :D
