Error message while loading VM
brunohppl
Post by brunohppl »
I have been tryng to load the VM file into Virtual Box, but everytime it shows:
Failed to open a session for the virtual machine Bitcraze VM 0.5.
The virtual machine 'Bitcraze VM 0.5' has terminated unexpectedly during startup with exit code 1.
Result Code: E_FAIL (0x80004005)
Component: Machine
Interface: IMachine {480cf695-2d8d-4256-9c7c-cce4184fa048}
Anyone know how to fix that up?
I have tried VMware as well, but it loads and the screen stays dark. Not sure if I am supposed to do something after that.
Re: Error message while loading VM
Which version of Virtualbox are you using?
Regards
Arnaud
brunohppl
Post by brunohppl »
Hi Arnaud,
I am using the VirtualBox 4.3.14
Thanks.
Can you create and run any other virtual machine with VirtualBox?
You can try creating a new virtual machine and launching it and see if you get the VirtualBox bios coming. I Google a bit and it could be a problem related to the VirtualBox installation: https://forums.virtualbox.org/viewtopic ... 64#p281864
Regards,
Arnaud
