Hello guys,
I am not sure if I have the same issue here. I always connect it on a flat surface; however a lot of messages pop up: 'Error when starting log config [AltHold]: no more memory available'; ''Error when starting log config [Baro]: no more memory available'; ''Error when starting log config [motors]: block too large'.
But I still can control it fine, and all the hardware seem to respond well; I am just wondering if the sensors are fine.
Anyone would have a guess?
Cheers
Problems when connecting
Re: Problems when connecting
I had similar issues when using a flie with outdated firmware! Try flashing itbrunohppl wrote:Hello guys,
Cheers
Yes, a firmware/client update will solve this. There's links to the latest releases in this post. Make sure to update both the client and the firmware.
/Marcus
/Marcus
