No thrust with PS2 controller. Roll&Pitch OK
ruza
Post by ruza »
I have a crazyflie quadcopter. I connect with it using a PS2 controller. The right joystick has no effect (thrust and yaw) either on the copter or the GUI. The left joystick seems to work well (as far as the GUI is concerned).
What's wrong? It did work 2 weeks ago.
Other details: battery > 3.8V. Link availability = 100%. Flight data GUI tilts when I manually tilt the copter.
I replaced the PS2 controller with a new one, but same problem.
Thanks to anyone who can help
Re: No thrust with PS2 controller. Roll&Pitch OK
Did you make sure to select the correct input device mapping? You might have selected another mapping and then some of the buttons/sticks might work and some others not (like PS3_Mode_1 for a PS2 pad). Check the lower left of the application where it says what input device and mapping you are using. Does it seem to match?
