Using ESKY transmitter AND Crazyradio
CrazyGuy
Post by CrazyGuy »
Is there a way to use an ESky transmitter and the Crazyradio at the same time?
I want to control the quad with an ESky transmitter but the telemetry data sould be send to the Crazyradio respectively the PC-Client. On my quad is the esky-firmware (build with "USE_ESKYLINK=1"). But if I click on connect/scan within the PC-Client my quad can't be found.
Thanks,
CrazyGuy :)
Re: Using ESKY transmitter AND Crazyradio
It is possible, only software ;).
We have actually thought about this but it is not obvious to implement since the two different protocols would have to be time divided, and unfortunately we don't have the time to implement it right now :(. I would be a great challenge if someone is up for it though :)
