Overflow memory
doddz
Overflow memory
Post by doddz »
Hi guys,
I've been playing around with making the altitude hold function run on a fuzzy logic engine instead of using PID. I've ran into this error.
/home/bitcraze/bin/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/bin/ld: cflie.elf section `.bss' will not fit in region `RAM'
/home/bitcraze/bin/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/bin/ld: region `RAM' overflowed by 388 bytes
My understanding is that everything I write is getting plopped into the RAM region because its undefined.
Could I specify my variables in a way they get put into the flash so it fits? Or maybe can I extend this area to have more space in the RAM...
doddz
Re: Overflow memory
If you have variables and structures that are only read (never written) then declare them const and they will only be stored in flash. If you are still short on memory then I would recommend reducing the FreeRTOS heap. The size of the heap is located in config/FreeRTOSConfig.h and you should be able to reduce it with at least the 388 bytes you are missing (you could probably reduce it with 1k without any problems).
