something wrong with the BusPirate4 to reprogram the cradio
baicker
Post by baicker »
i want to reprogram the chip nrf24lu1p with the bus pirate 4,
i connected the Bus Pirate and selftest with 0 error
then i connected the bus pirate with the crazyradio, and execute the command like this:
zsh@zsh-ubuntu-pc:~/crazyflie$ sudo perl ./flash.pl -input ./cradio-0.52.bin -device /dev/ttyACM0
Entering raw bitbang mode...
Entering binary SPI mode...
Configuring peripherals...
Configuring SPI...
Enabling programming...
Reading status byte...
Status: ff
Status isn't 0x20, write to device probably failed.  Check your connections. at ./flash.pl line 165.
Erasing chip...
then nothing happend.
are there anything wrong with my step ?
maxgeppi
Re: something wrong with the BusPirate4 to reprogram the cra
Post by maxgeppi »
Hi baicker
I'am try to do the same. and i've the same issue.
i think that the issue could be the power because during flash.pl i see that v3.3 remain down.
i don't known the bus pirate v4.0 and then i can't modify the code correctly.
During this year have you found a right solution to going on?
I'll wait a your welcome reply.
thank you in advance.
Max
