Can't Select Plotter in Client
vestige
Post by vestige »
HI
I have just update the whole things both client and firmware. In PC client i can't select Plotter tab, but before i have update i can still use Plotter tab. I have no Idea what happen :?:
How can i fix the client to allow it to use plotter tab like before the update?
Regards,
Danmark
Re: Can't Select Plotter in Client
Post by Danmark »
you are missing pyqtgraph
vestige
Post by vestige »
HI
So i have to download pyqtgraph isn't? and how can i relate pyqtgraph to the client?
Danmark
Post by Danmark »
What OS are you on.
on osx and linux you run
pip install pyqtgraph
from the command line
vestige
Post by vestige »
HI
I actually use the bitcraze VM 0.4
Danmark
Post by Danmark »
then pip install pyqtgraph should do the trick
vestige
Post by vestige »
Yes i have i have try to use ti but it need to install pip first. I have install pip already and to install sudo install pygthon-pip but it said that there is no distribution at all found for pygtgraph
What is happen is the pygtgraph already been install?
vestige
Post by vestige »
I have install pyqtgraph already but in the client I still can't use the plotter tab and logging configuration :?: :?:
Why i still can't use it?
Danmark
Post by Danmark »
try launching the client from a terminal and read the output.
python ~/projects/crazyflie-pc-client/bin/cfclient
vestige
Post by vestige »
HI
Yes i can use the plotter tab now. I just curious that how can i manage to edit the x and y axis in plotter?
