CF Client flightmode initial value
DesTinY
Post by DesTinY »
at first start of crazyflie-pc-client an error occurs (see image)
Main reason:
There is no initial value of flightmode (if "config.json in not there at first start") I can't find the right place for that :|
Side effect:
In "input.py" there is no initial value in "def __init__" for "minThrust" and "maxThrust" (line 258), too. And here dies the Client with the Pop-up (see image) if you give thrust with the controller.
Not high Prior but annoying if you forget too chose "Normal" as flightmode like me :roll: :lol:
Re: CF Client flightmode initial value
We did some updates to the client today, please try with that one, it should be more stable.
This problem should be fixed. The source-tree now contains the default config values that will be used to create the user config file config.json. There's still one more thing to fix but if you delete your old config.json and update to the latest version it should work. The bug that is left is: https://bitbucket.org/bitcraze/crazyfli ... not-copied
DesTinY
Post by DesTinY »
Great job guys :!:
I followed your commits the last few days and you guys have done a lot!
I can confirm my reported problem is solved in the latest revision!
The Client looks more and more quite stable, at least that I can test without a CF ( is shipped and on the way to me :lol: ).
thumbs up!
Because of me the Topic can be closed or deleted.
Thanks for testing. Yeah, it's been a busy weekend :D
