Public Service Announcement
orcinus
Post by orcinus »
Something i've just learned the hard(ish) way:
ALWAYS, and i mean ALWAYS check the target Thrust readout before you hit Connect.
ALWAYS.
I just had it stuck at 75% for some reason (the PS3 controller was connected, the stick wasn't pressed, it wasn't upside down or anything like that) and when i hit connect, my crazyflie flew off the table, bounced a few times against the ceiling, entangled itself into the window curtains, disentangled itself and slammed the wall a few times before i managed to react and hit the disconnect and the timeout kicked in.
What's even weirder - the PS3 controler was unresponsive until i've restarted the client, at which point it started behaving as usual.
aforcefulthrust
Re: Public Service Announcement
Post by aforcefulthrust »
LOL - Crazyflie still in good shape? I'm surprised at the beating these things can take.
csholmq
Post by csholmq »
Ouch, that's rough. Perhaps there should be some form of safeguard that prevents throttle above 0% when connecting for the first time.
orcinus
Post by orcinus »
Crazyflie is still fine, the props got a bit scratched, but nothing dramatic.
It's light enough that it can't do much damage to itself :)
A safeguard is definitely a good idea. Most RC systems initialize with the throttle disarmed and some kind of an arming "gesture" required before takeoff is possible. For a good reason :)
I've figured out what caused it, BTW. Cause #1 is disconnecting the controller with pygame still running. If you then reconnect, without restarting cfclient, the controller stick states will sometime get stuck in max. positions.
Cause #2 is controller going to sleep. Waking it up by pressing the PS button makes it resume normal function, though (unlike cause #1, which requires restarting cfclient).
