Changing Parameters in C++
rb13g11
Post by rb13g11 »
Hi
I've been using fairlight1337s C++ lib to control the Crazyflie from my PC, because I don't have any experience in python(even though my programming skills in C are pretty low). Available at https://github.com/fairlight1337/libcflie
I want to be able to change parameters, mainly turn altitude hold on or off. I've found the function that sends the Parameter packets in param.py:
def set_value(self, complete_name, value):
        Set the value for the supplied parameter.
        element = self.toc.get_element_by_complete_name(complete_name)
        if not element:
            logger.warning("Cannot set value for [%s], it's not in the TOC!",
                           complete_name)
        elif element.access == ParamTocElement.RO_ACCESS:
            logger.debug("[%s] is read only, no trying to set value", complete_name)
        else:
            varid = element.ident
            pk = CRTPPacket()
            pk.set_header(CRTPPort.PARAM, WRITE_CHANNEL)
            pk.data = struct.pack('<B', varid)
            pk.data += struct.pack(element.pytype, eval(value))
            self.param_updater.request_param_setvalue(pk)
I've adapted the function SendSetpoint to send parameters instead, using Port 2 and Channel 3:
bool CCrazyflie::sendParam(bool althold) {
	unsigned char varid = m_tocParameters->idForName("flightmode.althold");
	int nSize = sizeof(unsigned char) + sizeof(bool);
	char cBuffer[nSize];
	memcpy(&cBuffer[0], &varid, sizeof(unsigned char));
	memcpy(&cBuffer[1 * sizeof(unsigned char)], &althold, sizeof(bool));
	CCRTPPacket *crtpPacket = new CCRTPPacket(cBuffer, nSize, PARAMPORT, WRITECHANNEL);
  CCRTPPacket *crtpReceived = m_crRadio->sendPacket(crtpPacket);
  delete crtpPacket;
  if(crtpReceived != NULL) {
    delete crtpReceived;
    return true;
  } else {
    return false;
This successfully retrieves the element ID(varid) and places it in the second byte of the packet after the Header, and puts the values of althold afterwards.
This doesn't work. Could anyone give me advice as to what the problem is?
Thank you in advance
Kind Regards
Rushin
adiego73
Re: Changing Parameters in C++
Post by adiego73 »
Have you solved this? I'm trying to do the same, but I cannot accomplish it :(
Thanks in advance!
Diego.
