after connecting my crazyflie (in absolut horizontal position) the flight data window shows a light left bias/decline (not exactly hoizontal).
Is it possible to correct this somehow even if I'm not a program freak or software engineer?
In other words: Is it possible to calibrate the sensor mounted on the crazyflie?
Thanks, BR, Klaus.
Approving horizontal level Flight data
polarspan
Re: Approving horizontal level Flight data
You can use the trim buttons to correct drift of the Crazyflie during flight. Is there a big error in roll and pitch if you put it on a level surface?
polarspan
About one line on the left side.
My question was, if it is possible (e.g. via software) to get the flight data display in a absolute horizontale.
In other words: How can I be sure that the measurement resp. the chip itself is working best (Because normally if the crazyflie is leveled correct the display should deliver 100% horizontal adjustment, isn't it?)
Thanks and BR,
Klaus.
Thanks and BR,
Klaus.
There are many sources of error so it would be good to know what you finally want to achieve so I can help you better. There is currently no calibration function in the client but it is under development (slowly). However calibrating "level" is really difficult.
