what's the differences between these make options
do i need to program the bootloader into the stm32, or just program the cfile.bin is ok ?
[SOLVED] what's the differences between these make options
baicker
Re: what's the differences between these make options
To flash using the radio bootloader the bootloader must have been flashed before (which the Crazyflies are delivered with). When the Crazyflie is flashed with JTAG it will overwrite the bootloader. If you want to debug using the JTAG that is the only way though.
baicker
is the step right when i get a new stm32 chip?tobias wrote:To flash using the radio bootloader the bootloader must have been flashed before (which the Crazyflies are delivered with). When the Crazyflie is flashed with JTAG it will overwrite the bootloader. If you want to debug using the JTAG that is the only way though.
1 soldered the hardware
2 flash the bootloader to the stm32F103CB by jtag interface
3 use the crazyradio connect to the bootloader of the crazyflie, and program the cfile.bin
Yes that's it.
Steffen 2.0
Re: [SOLVED] what's the differences between these make optio
Is it possibly to replace the stm32?! That thing is so small
baicker
it's so big compared to the sensor or the wireliess chipSteffen 2.0 wrote:Is it possibly to replace the stm32?! That thing is so small
addme
You can easily check out our high quality N10-005 vce which for the 156-315.75 You can also get success in real hodges exam with the
Steffen 2.0
baicker wrote:it's so big compared to the sensor or the wireliess chipSteffen 2.0 wrote:Is it possibly to replace the stm32?! That thing is so small
baicker
1 soldered the hardwareaddme wrote:do i need to program the bootloader into the stm32, or just program the cfile.bin is ok ?
