Thrust rate won't zero
pablo_paul
I've just swapped over to a new windows 8 laptop i'm using the latest beta firmware and client. When I plug in the controller (cheap Chinese ps3 copy) the thrust is set to around 58% at null rate i tried mapping it out but for some reason the axis is inverted i.e. pull back thrust up push forward thrust down and it wont reverse when trying to map. Even when mapped reversed it still holds 58% at no input! All other axis are ok and map as expected. Has any one seen this behavior before?
Re: Thrust rate won't zero
In linux there is this joystick test program called jstest. Maybe something similar exist for windows to more easily debug the problem?
angleblue63
Nobody has any idea, what it might be?
Join online Pass4sure CLO-001 dumps and APPLE to pass pmp dumps exam in first try.
Do you have any other operating system to test it in (e.g. ubuntu)?
