is there a way to check the current Crazyradio firmware version on the command line?
I tried out the UI flash tool (cradioFlasher.py) which seems to be able to read out the version, but keep getting the following error:
QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No such file or directory
QFileSystemWatcher: failed to add paths: /home/<myusername>/.config/ibus/bus
Bus::open: Can not get ibus-daemon's address.
IBusInputContext::createInputContext: no connection to ibus-daemon Regards,
Fred
