Wire Strippers
wtsang02
Wire Strippers
Post by wtsang02 »
I did something stuipd and i cut all the heads of the motor wire by a little. Now I realize i need longer wire(head) so I would need something to strip off the plastic. Anyone have any ideas how I can do this? or a wire stripper (cheap) that can strip such thin wire? Thanks alot.
Re: Wire Strippers
They are not that difficult to strip. If you have a good tool that would be best but using a wire cutter, scissor or similar also works.
