Hallo!
I wrote my own ROS interface for the crazyflie using the python library. It worked!!! Now I changed the hold library with the new one but i don't receive the log_package.
(To write my code i used the examples in the wiki). I would to understand if is changed something or where is the problem!!
Cheers
No log_packace with the new library
marco.tognon
- Member
- Contact:
Re: No log_packace with the new library
This could be due to some renaming in the API, it depends a bit on what you mean by old and new version. Could you copy/paste the output from the application in the console?
marco.tognon
- Member
Marcus do you mean the output of my application?
With new I mean the last version, with old I mean the version before the hover mode.
- Contact:
Yes, if you configure the logger it should print out debug info from the library in the console. Use this code in your application to configure it.
import logging
logging.basicConfig(level=logging.DEBUG)
