Crazyflie resistors part number?
crazyflie_IC
Post by crazyflie_IC »
I've experienced a problem described somewhere in this Forum: probably due to a short-circuit, the voltage regulator and the 10k R2 resistor got damaged.
Does anybody know the resistor part number, since it does not seem to be just a common 10k-resistor? I've found references about the regulator, nothing on the resistors.
Thanks in advance
Re: Crazyflie resistors part number?
The resistor is a standard 0603 50V 1% resistor.
