Removing support for the Flow deck from the firmware breaks the LED ring deck
MichaelNdu
Post by MichaelNdu »
I was customizing the firmware using the new Kbuild system, and I removed support for a bunch of expansion decks I wasn't planning on using, but after I flashed the crazyflie with the firmware, I noticed I no longer had the ability to control the LED ring deck via parameters. I was unable to set the ring effect or control individual LEDs, or turn on the LED headlight anymore, and it was only after some trial and error that I discovered that the ability to do this appeared to depend on Flow deck support being included in the firmware.
For now, I've just included that, since I need the ability to set LEDs dynamically, but just thought I'd bring some attention to this issue.
Re: Removing support for the Flow deck from the firmware breaks the LED ring deck
Hi! Thanks for letting us know. As you see above, we are moving to https://discussions.bitcraze.io/ so there will not be somebody to comment on this soon if you would like this to be part of a discussion. Would you like to repost it there? if not let me know and I can make an ticket for it.
MichaelNdu
Sure thing, will move this topic over to the new discussions page
thanks!
