Use with lighthouse deck and multi-ranger deck
Eunju Jeong
Post by Eunju Jeong »
Hello!
It is possible to attach a lighthouse deck and a multi-ranger deck to one crazyflie2.1?
I want to use a multi-ranger deck to measure the distance from the wall and use a lighthouse deck to get the position information of the crazyflie at the same time.
Thank you.
Re: Use with lighthouse deck and multi-ranger deck
I don't think we ever tested that, but I as far as I can see it should work.
You would have to mount the Multiranger deck under the Lighthouse deck or under the Crazyflie, which means you will block the up-sensor. This is not a problem but you will obviously not get any information from it.
You will probably need the extra long pins as well (https://store.bitcraze.io/products/male ... 53ad&_ss=r)
