Can't flash ESP firmware
Discussions about the AI-deck
tag2022
Post by tag2022 »
Hello.
I can't flash ESP firmware. I installed everything else successfully.
I did everything according to the instructions on https://www.bitcraze.io/documentation/t ... p-firmware
$ git clone https://github.com/bitcraze/aideck-esp-firmware.git
$ cd aideck-esp-firmware
$ tb build
$ cfloader flash build/aideck_esp.bin deck-bcAI:esp-fw -w [your radio uri]
And I got this message.
:~/aideck-esp-firmware$ cfloader flash build/aideck_esp.bin deck-bcAI:esp-fw -w radio://0/80/2M
Reset to bootloader mode ...
Could not save cache, no writable directory
Version 3 not supported
I get the same error when I follow the instructions from here: https://www.bitcraze.io/documentation/r ... -streamer/
$ cd aideck-gap8-examples
$ docker run --rm -v ${PWD}:/module bitcraze/aideck tools/build/make-example examples/other/wifi-img-streamer image
$ cfloader flash examples/other/wifi-img-streamer/BUILD/GAP8_V2/GCC_RISCV_FREERTOS/target.board.devices.flash.img deck-bcAI:gap8-fw -w radio://0/80/2M
:~/aideck-gap8-examples$ cfloader flash examples/other/wifi-img-streamer/BUILD/GAP8_V2/GCC_RISCV_FREERTOS/target.board.devices.flash.img deck-bcAI:gap8-fw -w radio://0/80/2M
Please, help.
Re: Can't flash ESP firmware
The memory mapping API has changed (between Crazyflie and Python lib) and the slightly sparse error message "Version 3 not supported" means that the python lib does not support version 3. All you have to do is to upgrade your python lib to the latest and greatest, that is to check out the repository (https://github.com/bitcraze/crazyflie-lib-python) and install the source code using "pip install -e ."
The memory mapping API has been updated in the recent work with the AI-deck and all components will be synchronized in the next release. we are working on releasing and it should hopefully be out soon.
tag2022
Post by tag2022 »
Thank you very much! It worked.
Now I'm trying to install this example https://www.bitcraze.io/documentation/r ... -streamer/,
but I've encountered that the process hangs at 2%.
I got:
Skipping bcAI:esp, not in the target list
Deck bcAI:gap8, reset to bootloader
| 0% Writing to bcAI:gap8 deck memory
/ 1% Writing to bcAI:gap8 deck memory
- 2% Writing to bcAI:gap8 deck memory
Could you help please?
It is very hard to say exactly what happened.
Did you try to flash it again? Did you get the same result?
earny
Post by earny »
it's hanging for me too, any advice how to solve it ?
SOLVED
The issue was that i was passing address with the URI. If anyone is struggling with it replace radio://0/80/2M/E7E7E7E7E7 with radio://0/80/2M : )
Great! This was also mentioned in discussions as well, and we will probably investigate this as this is a bit not logical that this will happen.
https://github.com/orgs/bitcraze/discussions/57
Let's further discuss on discussions.bitcraze.io!
