is the debug adapter compatible with the AI deck?
Discussions about the AI-deck
dominik.natter
Post by dominik.natter »
Hei,
when reading through the AI deck description in the shop I read "To program this board a compatible JTAG programmer/debugger is needed, see resources.". Under resources, I didn't find anything else about debuggers. I wonder whether the Debug Adapter Kit from your shop would qualify as one? If so, maybe it's good to specify that more clearly :)
Best,
Dominik
Re: is the debug adapter compatible with the AI deck?
You can use the debug adapter kit the go from the 20 pin thick ribbon cable from the Olimex ARM-USB-TINY-H JTAG (Jlink should work too), to a thinner 10 pin cable that you connect to the AIdeck.
It was usually part of the AIdeck documentation, but now it has disappeared (except for this image).
