I am trying to reflash the crazyflie 2.0 after installing a lighthouse positioning deck and updating the firmware as the directions on the bitcraze website required. Now when I turn on the Crazyflie only the blue M2 led is lighting up steadily (not Flashing). I think I may need to reflash the crazyflie but I am confused on the steps of doing that. Can anyone explain to me how to reflash the crazyflie 2.0. I am also using the virtual machine not the windows version of the client software.
Thank you
Crazyflie 2.0 Reflash
Re: Crazyflie 2.0 Reflash
Could it might be that you have flashed a non-crazyflie firmware on there? It sounds a lot like the same problem some others had, after they flashed a Bolt firmware for instance which usually results the M2 blue led to be on all the time.
These are the instructions to reflash the crazyflie in recovery mode: https://www.bitcraze.io/documentation/r ... very-mode/, and ofcourse make sure you use the firmware for cf2.
Let us know if this works!
