GAP8 JTAG semihosting
Discussions about the AI-deck
rsantosc
Post by rsantosc »
I've been trying to use the GAP8 jtag semihosting for logging but without success... Can you give me some pointers on how you have configured gap8-openocd and which commands to run using the aideck docker image?
Is there any documentation (or external tutorial) you recommend for debugging the GAP?
Cheers,
Rui
Re: GAP8 JTAG semihosting
For the semi-hosting it might be that the settings in the project is set for UART, have a look in the Makefile where the following should be seen:
io=host
In most of the code now we have io=uart instead, like in the GAP8 bootloader (link).
For more information on using the GAP8 with JTAG I think the best documentation for it is here.
