I cannot change the connection settings on my android app, they are all "gray". I granted all the permissions to the app but it still does not work. Because of that I am not able to connect or scan for the drone...
I also can connect via Bluetooth on my phone (I can see crazyfile there) but when I am trying to do it via app, it does not seem to be working or detecting the drone...
What is the solution for that?
Connection settings on Android app do not work
m.wozniak94
Re: Connection settings on Android app do not work
I believe that the grayed out connections settings only are enabled when you plugin a crazyradio, as these are not necessary for bluetooth. See the instructions of the android app here, but if you are experiencing more issues, perhaps best is to make an issue on the github page
