Cannot testing the Himax camera
Discussions about the AI-deck
Mathilda
Post by Mathilda »
When I try to run the "Testing the Himax camera", it will always stop at certain point like below:
Therefore, I try to find the program stop at which scentence,and find:
But 3 of my teammates can run this example successfully, and we have the same virtual envirnment.
So, I want to know is this problem may be caused by computer configuration? or there are other causes?
By the way, my teammates and I all used the offical docker. And we refer to this page:https://www.bitcraze.io/documentation/r ... st-camera/
Regards,
Mathilda
gemenerik
Re: Cannot testing the Himax camera
Post by gemenerik »
Hi Mathilda,
Curious... Are you using the same JTAG debugger, too?
We have seen similar unexpected behavior of the GAP8. I have found that it can help to first connect the JTAG debugger, before powering on the board. Give that a try and let me know if it works!
Mathilda
Post by Mathilda »
Hi gemenerik,
Thanks to your solution,it works!!!!!!!!!!
I met this problem nearly two weeks, thank you very much!
Sending you a heart!!!!!
Regards,
Mathilda
