FaceDetection Example
Discussions about the AI-deck
BadWoman
Post by BadWoman »
Hi, are we able to run the face detection example on the Bitcraze VM work environment? If so, how should I do it?
BadWoman
Re: FaceDetection Example
Post by BadWoman »
So currently I followed the Docker Gap8 instruction thoroughly and got to this part of the FaceDetection. I don't understand how can I use the viewer.py to see the image streaming.
Hi! please see these instructions. https://www.bitcraze.io/documentation/r ... detection/
In the make file you need to uncomment the two defines as indicated at the bottom of the instructions. We will need to update the text as both streamer and camera should work in SDK 3.8
BadWoman
Post by BadWoman »
It works now! However, the stream image is upside down somehow. Is there a way to fix that?
Awesome!
yeah the upside down image was an issue but that should actually be fixed now since this issue: https://github.com/bitcraze/AIdeck_examples/issues/51
are you sure that you have pulled the latest changes of the AIdeck_examples repo?
BadWoman
Post by BadWoman »
I might not have done that yet. How should I pull the latest AIdeck_examples again?
Probably a 'git pull origin master' will suffice. But if you did a lot of changes to the code already, you can also just try a new git clone of the repo
