Can't see changes to radiodriver.py
traffens
Post by traffens »
Good afternoon,
I'm trying to edit the radiodriver.py file with a simple command to prove that my changes i'm making are being applied in cfclient.
I'm running this on the most recent bitcraze VM.
crazyflie-lib-python/cflib/crtp/radiodriver.py
logger.info('v%s dongle with serial %s found', cradio.version,
                        serial)
I'm changing this to:
logger.info('v%s dongle with serial %s found WITH CHANGE HERE', cradio.version,
                        serial)
Then, I go to crazyflie-lib-python and
make venv
afterwards I run
cfclient
and the output i get is
but I never see my change in the console. Why is this?! Where am I going wrong? I've been losing my mind over this.
traffens
Re: Can't see changes to radiodriver.py
Post by traffens »
Turns out, this is not the radiodriver file that my path refers to. the actual file was installed by pip. the location of the file for me was:
 /home/bitcraze/.local/lib/python3.8/site-packages/cflib/crtp/radiodriver.py
*cries violently*
jonasdn
Post by jonasdn »
You could use:
pip3 install -e .
To install your local copy as "editable install" then your edits will take effect at once.
