Firmware "Failed to flash" error
traffens
Post by traffens »
Good evening all,
I've created my own custom firmware by following the guide:
https://www.bitcraze.io/documentation/r ... ystemtask/
I followed this guide to a T except I replaced any word "example" with "pairing". after doing this, the makefile successfully runs, however when I run
Make cload
it will fail with the following message:
bitcraze@ubuntu:~/Desktop/projects/crazyflie-firmware$ make cload
python3 -m cfloader  flash  cf2.bin stm32-fw
Restart the Crazyflie you want to bootload in the next
 10 seconds ...
Failed to flash: 'NoneType' object has no attribute 'group'
EDIT: I imported traceback and have it here:
 10 seconds ...
  File "/home/bitcraze/projects/crazyflie-clients-python/src/cfloader/__init__.py", line 155, in main
    bl.flash_full(None, filename, warm_boot, targets)
  File "/home/bitcraze/projects/crazyflie-lib-python/cflib/bootloader/__init__.py", line 207, in flash_full
    if not self.start_bootloader(warm_boot=warm, cf=cf):
  File "/home/bitcraze/projects/crazyflie-lib-python/cflib/bootloader/__init__.py", line 105, in start_bootloader
    uri = self._cload.scan_for_bootloader()
  File "/home/bitcraze/projects/crazyflie-lib-python/cflib/bootloader/cloader.py", line 86, in scan_for_bootloader
    res = link.scan_selected(self._available_boot_uri)
  File "/home/bitcraze/projects/crazyflie-lib-python/cflib/crtp/radiodriver.py", line 362, in scan_selected
    one_to_scan['channel'] = int(uri_data.group(4))
AttributeError: 'NoneType' object has no attribute 'group'
How can I troubleshoot this further? is there something not shown in the guide above that I need to do?
Re: Firmware "Failed to flash" error
Have you started your Crazyflie in bootloader mode? This is done by holding the ON/OFF switch until the M2 LED starts blinking, then both M2 and M3 should blink and you should be able to run make cload without problems.
traffens
Post by traffens »
Regardless of whether or not it's in bootloader mode (and yes I did), the error still comes.
This is strange, I have seen this error when another Crazyflie was present on channel 0 or 80, so I could imagine it happening if you are not in bootloader mode. Though, it should work if the bootloader is launched on the Crazyflie
Are both blue LED blinking when the Crazyflie is in bootloader mode? Does the M4 LED blink a little bit when you launch the make cload?
You can also make sure you are running the latest version of the lib by running the update all script in the VM an that your USB radio is well passed to the VM.
traffens
Post by traffens »
both blue LEDs are blinking when I start the cload. I haven't actually watched them when I run the command, I'll try that later today.
I'll try updating all the projects and then flash again.
What's confusing to me is that the make cload should time out after 10 seconds, not immediately error out when I run make cload. This leads me to believe the problem lies elsewhere.
traffens
Post by traffens »
I've rotated through like 4 vms during this process due to anomalistic errors that come up outta nowhere. Did some cloning/copying on to Ubuntu 20.04 and it worked.
So why does this happen on the bitcraze VM though? how can I keep troubleshooting this?
jonasdn
Post by jonasdn »
Perhaps this is better suited as a GitHub issue as it regards code directly, would you mind filing one at https://github.com/bitcraze/crazyflie-lib-python/issues ?
Please include what version of the lib you are using, you can get this information by: $ pip show cflib
The code that has problem seem to be:
def scan_selected(self, links):
        to_scan = ()
        for link in links:
            one_to_scan = {}
            uri_data = re.search('^radio://([0-9]+)((/([0-9]+))'
                                 '(/(250K|1M|2M))?)?',
                                 link)
Where uri_data seem to be None so it does not detect a radio-uri for some reason. Are you sure the VM has detected the dongle?
You could modify the code to print the 'link' variable here to see what the lib things it is working with.
Jonas
traffens
Post by traffens »
The error I had was an out-of-date radiodriver.py. Apologies for the frustrations. You guys are great
