I have set up the environment my self with downloading the virtual machine. I can run the command "make cload" and connect with the crazyflie 2.1 but I am not sure where to go from here.
I want to program preferably in c++/c but what is the next step. How do i run a code on it? How do i extract relevant information (roll pitch yaw etc etc)?
I have found this: https://www.bitcraze.io/documentation/r ... ides/deck/ but it is for crazyflie 1
Hope someone can help me. Previous posts from the forum will be nice.
And where do i download the rest of the things in the virtual machine?
What are the next step after I can run the command "make cload"?
JamesClark
jonasdn
Re: What are the next step after I can run the command "make cload"?
Hi James!
You can start looking here: https://www.bitcraze.io/documentation/r ... re/master/!
And if you want to program in C and have code on the Crazyflie, more specifically here: https://www.bitcraze.io/documentation/r ... app_layer/
And for extract information, check out the logging framework: https://www.bitcraze.io/documentation/r ... /api/logs/
Happy hacking!
Jonas
Happy hacking!
Jonas
