Telemetry Lost After 2-3 Seconds
radutolontan
Post by radutolontan »
Hello all,
I am using a Crazyflie 2.0 and a Crazyradio PA with the Bitcraze VM. I have updated both the firmware of the Crazyflie (2021.06 CF2) and the Crazyradio (0.53). When I use the client to connect to the Crazyflie, telemetry is up for 2-3 seconds and then it freezes; however, the connection says is still up. The drone passes the self test and is fully flyable using the IOS app. I looked up similar issues on the forum and I ended up changing the Data Rate to 2MBps on both the dongle by modifying the crazyradio.py file and on the drone by using the client "Configure 2.X" window; no success however.
Thanks for your help
jonasdn
Re: Telemetry Lost After 2-3 Seconds
Post by jonasdn »
Hi radutolontan!
Some quick questions!
  1. Are you using a MAC or a PC?
  2. Are you using USB3.0? This has been known to interfere with Crazyradio PA
Jonas
radutolontan
Hey Jonas,
Thank you for your reply! I am using a MAC computer which only has USB 3.0 ports.
Best,
Radu
jonasdn
Post by jonasdn »
Hi radutolontan!
We have known issues with USB 3.0, the frequencies does not play nice with our CrazyRadio PA. We are starting wok on a CrazyRadio 2 prototype to resolve this issue among others.
As a workaround maybe you could try an USB 2.0 Hub of some sorts?
Thanks and sorry
Jonas
