Failed to make web request to get firmware-release
steve
Post by steve »
When starting cfclient (on MacOS, installed via brew), I get the following in the terminal:
WARNING:cfclient.ui.dialogs.bootloader:Failed to make web request to get firmware-release
WARNING:cfclient.ui.dialogs.bootloader:Failed to parse firmware-releases in web request
In bootloader I don't see anything in the 'available downloads' dropdown. This happens even when running sudo cfclient.
I assume these two are connected -- any ideas? Can't find anything here in search, and no luck looking for things that might block Python apps from accessing the web.
Thanks,
Steve
Re: Failed to make web request to get firmware-release
We haven't really seen this before. Is this perhaps due to some restrictions of your network? Have you tried it with your wifi at home or at work/university?
It is also possible to get the releases here: https://github.com/bitcraze/crazyflie-release/releases and then use the tab 'from file'. but it would be good to figure out why it is not working for you.
