Why is “crossing beam” position method so stable?
gahagaha
Post by gahagaha »
Hello, I have some questions about “crossing beam” location method. Why is this position method so stable In UAV position? What should be done when the positions of the four sensors on the deck are calculated, but one point is calculated far away from the other three points?
Re: Why is “crossing beam” position method so stable?
Do you mean that the forth point is an outlier or that one of the sensors has been moved out?
