LH2 Mounting on a Truss
whoenig
Post by whoenig »
Does anybody have recommendations for mounting the LH2 basestations on a truss (rather than on the wall)? Specifically, I am using a Global Truss F34 with 50mm diameter tubes. I didn't find any information regarding that in the getting starting guide at https://www.bitcraze.io/documentation/t ... ighthouse/.
Re: LH2 Mounting on a Truss
We have been using the "Manfrotto 035 Superclamp" on our truss to setup the lighthouse basestation and they work quite fine. We have a Global Truss F23 so it is a bit thinner, but the clamp is documented to work with up to 55mm tubes.
whoenig
Post by whoenig »
Thanks Arnaud!
