Greetings all,
for some time I was working with Lighthousesystem now. Lately I was noticing some things about he accuracy of the Lighthousesystem V1.
After a couple of hours and with increase of operating hours the accuarcy of the position estimation with the Lighthousesystem is getting worse. It gets to point, where the change in yaw is only detected in a small degree.
Is that a known issue with Lighthousesyetm V1 or is the issue on my end/hardware?
Will I get similar results with using the Lighthousesystem V2 ?
Kind regards,,
dpl
Lighthousesystem accuracy
Re: Lighthousesystem accuracy
It is hard to understand what is getting worse and how. Can you try to elaborate and possible share some data that shows the problem?
