Cannot flash custom firmware
droneteamNOK
Post by droneteamNOK »
I'm trying to get the crazyflie 2 and the lighthouse deck to work with multiple steamvr -basestations. From what I understand I need to edit the firmware and flash it to the drone, specifically the
#define PULSE_PROCESSOR_N_BASE_STATIONS
in pulse_processor.h from 2 to a larger number, in my case 4. I have done this and zipped the custom firmware, but when I try to flash it to the crazyflie with cfclient, the client says "Flashing" for a few seconds, then for a tiny amount of time it says "Resetting to firmware, disconnected" and then disconnects the drone. How can I make the client not do this?
Re: Cannot flash custom firmware
Support for more then 2 basestations doesn't work yet. Please see this thread where it is also discussed.
narulaprince65
Post by narulaprince65 »
I have the same issue. Any tips for solution? spice money
teatv apk
jonasdn
Post by jonasdn »
Before we start debugging the flashing issues please make sure you have the latest version of both the cfclient and the cflib!
You can check the versions by:
$ pip show cflib
$ pip show cfclient
And you can attempt to upgrade them by:
$ pip install --upgrade cflib --user
$ pip install --upgrade cfclient --user
Jonas
