I seem to have disconnected a Crazyflie 2.1 midway through an update, and now when it is turned on only a single blue LED (M2) turns on. I searched through the forum and found a couple of mentions of this problem, but most of the solutions seemed to lead to defunct links or solutions that didn't work when I attempted them (perhaps meant for previous versions of the CF?). I tried following the steps in viewtopic.php?f=5&t=1801&start=10 and viewtopic.php?t=2947 and was unsuccessful.
So - I am able to hold down the power button when reconnecting the battery (or connecting the CF to a computer), and the blue light will change to either a slowly flashing mode, a quickly flashing mode, and a mode where both M2 and M3 turn on and off, slightly desynchronized from each other. I am unable to connect it to the client in any mode except for when the two lights are flashing, and when I do this, the client will find the CF in a scan, and then attempt to connect (with no success) for as long as I leave it on (longest attempt was half an hour, which seemed like more than enough time to assume something had failed). I also tried switching to the Cold Boot (Recovery) tab, but any attempts to use this were met with the error message start_bootloader() got an unexpected keyword argument 'cf'
Any ideas of how to work this out? Thanks!
Single Blue Light on M2 (Sometimes M3)
DM7299
- Member
Re: Single Blue Light on M2 (Sometimes M3)
It seems that your cfclient and cflib versions are not rightly aligned. Did you install the cfclient from source?
The quickest to solve that is to do the following:
The latter will also install the right version of cflib as well.
Let us know if you can now do the recovery boot!
pip3 uninstall cflib cfclient
pip3 install cfclient
DM7299
- Member
It works now, thank you!
