Camera
Re: Camera
Are you referring to the AI-deck? There is a getting started example, the "Wifi video streamer".
BadWoman
- Member
Re: Camera
This is the error that I have when I try to use python3 viewer.py
Re: Camera
Since you are using the on RAM flashing, (make run), then ctrl c will close that session and stop the process. So by the time you start the viewer, it already stopped.
You need to either flash the gap8 fully (make flash) or while this terminal is one with the onram session on, you open a new terminal for just the python viewer
Re: Camera
Also don't forget to connect to the wifi of the aideck. That is necessary for the viewer too.
If you are a beginner, I highly recommend you to watch the recording the aideck workshop we had a few months ago
