UART Protocol GAP8 <-> STM | DEBUG_PRINT issue?
bot-motion
Post by bot-motion »
I'm trying to build a simple protocol on top of the UART between GAP8 and STM.
But even detecting a protocol header does not work properly. If it turns out that it is my own inability and lack of C knowledge, just ignore me :? - but I think what I observe may have something to do with the DEBUG_PRINT define.
All of the following is part of aideck.c and readUartMessage() is called from Gap8Task()
The attached screenshots show what I see in the console and what I see in the terminal where the cfclient is running.
I obviously receive the header both on the flie as well as in the cfclient, but why does all this other stuff show up? 0xBC - that sounds familiar. Is this part of the crazyradio protocol, and if yes, why does it appear?!
Screenshot 2021-05-22 2.png (36.31 KiB) Viewed 3138 times
And why does the decoding of the message in the cfclient fail?
Any pointers to what I need to adjust would be welcome. Thank you!
#define HEADER_LENGTH 4
#define BUFFER_LENGTH 2
#define HEADER "!INO"
static uint8_t header_buffer[HEADER_LENGTH];
static uint8_t rx_buffer[BUFFER_LENGTH];
bool rxHead()
    uint8_t *rx_ptr = header_buffer;
    bool rx_valid_header = false;
    int i = 0;
    while(i < HEADER_LENGTH)
        bool no_timeout = uart1GetDataWithDefaultTimeout(rx_ptr);
        if(no_timeout)
            consolePutchar(*rx_ptr);
            rx_valid_header = (*rx_ptr == (HEADER)[i]);
            if (rx_valid_header)    // check if the next byte fits the protocol's predefined header
                rx_ptr++;
                i++;
            else
                break;
        else
            break;
    return rx_valid_header;
void readUartMessage()
    bool valid_msg_start = rxHead();
    if (valid_msg_start)
        DEBUG_PRINT("HEAD! %s \n", (char *)header_buffer);
bot-motion
Re: UART Protocol GAP8 <-> STM | DEBUG_PRINT issue?
I forgot to mention: the GAP sends
!INOxx
where xx = uint16 (two bytes). So the two squares in the console readout of cfclient after the letters are explained. It's generally why the decoding fails that I don't understand. Why does it show 0xBC<square>P<square>?
Could it be because the string is not NULL terminated? HEADER_LENGTH is 4 and should be 5 to account for the NULL termination.
