wifi configuration
Discussions about the AI-deck
dmill207
wifi configuration
Post by dmill207 »
Hello
I'm a student that recently started using BitcrazeVM for the AI deck.
I'm in a classroom with multiple students using the AI deck. Is there a way for us to configure the wifi address on the AI deck so we don't interfere with each other's work?
V/R
Dorian
Re: wifi configuration
This depends a bit on how you are connecting to the deck.
If you're using it as an access point then you can set the access point name in the wifi.h file, here's a link to the line on GitHub.
If you're using it by connecting to an access point then I think it would be best to first talk to the IT department how they suggest doing this. It's possible to set static IP-addresses for the wifi, but I don't think the IT department would appreciate this without talking to them first.
dmill207
Post by dmill207 »
I'll talk to IT management about this issue.
