Trouble updating CrazyRadio firmware
floyd871
Post by floyd871 »
I am runnig the Bitcraze-VM under Windows 7 64bit.
Flying ist i litte bit complicated, but i will figure it out!
Now i want to update the Firmware. I open a Terminal an enter:
bitcraze@bitcraze-vm:~/projects/crazyradio-firmware$ python usbtools/launchBootloader.py
Launch bootloader ....
Error!, bootloader not started
After that, the USB CR-Dongle just disapears form the VM and the Host!!!
Error!, cannot find the CrazyRadio USB dongle!
Who can help?
Re: Trouble updating CrazyRadio firmware
Did you follow the instructions on the wiki because the Crazyradio will appear as a new device?
"Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named nRF24LU1P-F32 BOOT LDR will appear. If you do not have a filter set up for the bootloader in the VM then script will say that it failed. This is ok. Pass the bootloader device into the VM and continue."
floyd871
Post by floyd871 »
Yes i have followed the instructions in the Wiki, but the New Device does not appear under the new name, so i can bind it in the VM.
Under my host OS (Windows 7) ist must appear as well, right ??
Yes it should appear as a device in win7 if the bootloader managed to start, but it doesn't?
floyd871
Post by floyd871 »
Yes correct. Under Win7 the Device ist gone no new device appear.
floyd871
Post by floyd871 »
No i have tried with a different Computer at my workplace with running pure Linux (Ubuntu).
After a few problems with pyusb and missing udev rules, i have managed updated the firmware.
Now at home i have tried the procedure under Win7 and Linux-VM, but no change. After start of the bootloader (vm) the device is gone.
Wit a scanner in the Windows Host i did NOT see the Crazyradio device with a different id (0101) or the old (7777) one.
Did anyone do the update within the VM and a Windows Host?
I updated the firmware, but the problem is not solved.
There was a bug in the firmware versions < 0.52 that could cause problems with updating from a virtual machine. But I'm guessing that you flashed the latest version (0.52) so that should be solved.
When I try this I still get the same messages as you do, but I get the new device as well. It's called Nordic Semiconductor nRF24LU1P-F32 BOOT LDR. I have Linux as host, but I'm running the Bitcraze VM 0.3 to launch the bootloader and flash the new firmware.
floyd871
Post by floyd871 »
Yes, i have flashed the last version (0.52). But under my Windows Host with the VM the Device is still missing after bootloader launch.
So, this might be a Windows problem. :(
