install cflib
ofirnag
install cflib
Post by ofirnag »
o keed getting eror by try tou intall this package.
can you help me?
(WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='pypi.org', port=443): Read timed out. (read timeout=15)")': /simple/cflib/)
and in pycharm also uts dosnt work/
Re: install cflib
Can you please give us a bit more information about what you are trying to achieve and how. Most important information are:
- What OS are you running
- What do you want to do
- What steps have you followed so far
- At what step are you blocked, what was the command and what is the error message
I am sure that with more information we will be able to help you.
ofirnag
Re: install cflib
Post by ofirnag »
i want to run this code on Crazyflie 2.1., i have all deck.
https://www.bitcraze.io/documentation/t ... ng-bundle/
this line "pip3 install cflib" give eror and its the first thing i need to do to start.
Re: install cflib
What operating system are you running on and what version of python are you using?
