TOC problem[SOLVED]
applep1e
TOC problem[SOLVED]
Post by applep1e »
HI,
I was trying to find how to get the state data of the drones. In various links and tutorials, I learned how to log the variable by cflib.
and i wonder where i can find document about TOC. To be more specific, what the difference between stateEstimate.x and kalman.stateX? where i can find all the variable list more easily?
it's too annoying when i use cflib do something, i need to disconnect the cfclient first, and when i misspell some variable, i need to reconnect and check it, and i am not good at programming (tracing variable in firmware to understand TOC is not easy work for me...), so i wonder if there is a document about all TOC variable.
- Thanks!
Re: TOC problem
Unfortunately the only document for the log variables so far is the Crazyflie source code. We have been talking about adding comments to the logs and param (including units and enum name for the variables that are enums), but this is still in the (long) todo list...
One thing that may help you is the cache files for the log and param toc. In the client if you go in the menu "settings/open config folder" you can find a cache folder that contains json files. They are named after the hash of the TOCs and they contain the log or param TOCs. To get the one used in your Crazyflie you can delete all the file, connect your Crazyflie, and the 2 created files will be the TOCs for your Crazyflie. You can use that to get the spelling and types of all the variables. It looks like this:
 "pwm": {
    "m1_pwm": {
      "__class__": "LogTocElement",
      "ident": 6,
      "group": "pwm",
      "name": "m1_pwm",
      "ctype": "uint32_t",
      "pytype": "<L",
      "access": 0
    "m2_pwm": {
      "ident": 7,
      "group": "pwm",
      "name": "m2_pwm",
      "pytype": "<L",
      "access": 0
    "m3_pwm": {
      "ident": 8,
      "group": "pwm",
      "name": "m3_pwm",
      "pytype": "<L",
      "access": 0
    "m4_pwm": {
      "ident": 9,
      "group": "pwm",
      "name": "m4_pwm",
      "pytype": "<L",
      "access": 0
And to answer your question: stateEstimate.x and kalman.stateX are the same things when using the Kalman filter. We have two variables for historical reason and since they are both used in tools and clients and we have no way to depreciate variables, we kept both.
applep1e
Re: TOC problem
Post by applep1e »
Thanks for your reply, and i will work hard to understand code. :D
