gap_sdk v-3.8.1
Discussions about the AI-deck
1pi
gap_sdk v-3.8.1
Post by 1pi »
Hello
I have upgraded the gap_sdk to version 3.8.1, when I try to program the face detection example I get this message
ModuleNot Found error:no module named ‘elf tools’.
I tried to install pyelftools with pip but still getting the same message. I am using Ubuntu 18.04.
Regards
Rodrigo
yaooooo
Re: gap_sdk v-3.8.1
Post by yaooooo »
Can you please check which version of pip you are using?
It seems a problem of python package management. We strongly recommand you to use "Anaconda": https://www.anaconda.com/products/individual
After installing the Anaconda, please configure a env for python3, then install all the packages in the sdk/requirements.txt
You can run :
pip install -r requirements.txt
If you don't want to use anaconda, then please make sure you are using python3 and pip3 for installing the pacakges.
You can do an easy test:
$python or $python3
<Normally you will see your python version>
>>>> import elftools
Regards,
Yao
