[SOLVED]ARM-JTAG-20-10 vs ARM-USB-TINY-H for the AI deck
Discussions about the AI-deck
Sadeem
Post by Sadeem »
What is the difference between ARM-JTAG-20-10 and ARM-USB-TINY-H?
Also, what is the most necessary for the AI deck? And if so, how many for one AI deck?
Thank you.
Re: ARM-JTAG-20-10 vs ARM-USB-TINY-H for the AI deck
The ARM-JTAG-20-10 is a 20 pin to 10 pin adapter for the olimex, and ARM-USB-TINY-H is the programmer itself. Both is necessary to program the AIdeck, where you put the ARM-jtag-20-10 on the ARM-USB-TINY-H and connect the 10 pin lint cable (from the arm-jtag-20-10) to the deck. See the rest of the documentation here: https://github.com/bitcraze/AIdeck_exam ... ramming.md
You need one set of these for the AIdeck and same programmer+adapter set can be used for both the NINA and the GAP8 chip. Here is more documentation:
