Detecting a deck using the code from the step by step motion commander tutorial.
cafeciaojoe
Post by cafeciaojoe »
hi!
I am following the motion commander tutorial, after copy pasting the code below direct fromt the tutorial, I cannot detect a deck.
The CF is running the latest release firmware with a blank config.mk file.
I get the following from the console, no matter if a deck is attached OR what kind of deck is attached, (flow, lighhouse, led...)
Connecting to radio://0/80/2M/E7E7E7E7E7
Connected to radio://0/80/2M/E7E7E7E7E7
0
Deck is attached!
Process finished with exit code 0
import logging
import time
import cflib.crtp
from cflib.positioning.motion_commander import MotionCommander
URI = 'radio://0/80/2M/E7E7E7E7E7'
is_deck_attached = False
def param_deck_flow(name, value):
    global is_deck_attached
    print(value)
    if value:
        is_deck_attached = True
        print('Deck is attached!')
    else:
        print('Deck is NOT attached!')
if __name__ == '__main__':
        scf.cf.param.add_update_callback(group='deck', name='bcFlow2',
                                         cb=param_deck_flow)
        time.sleep(1)
Thanks in advance.
PhD Student
RMIT University
School of Design
http://www.cafeciaojoe.com
Re: Detecting a deck using the code from the step by step motion commander tutorial.
hi joe!
I will try this this afternoon. It should work but maybe somethings off. I will give an update once I do!
you are right. The value is received as a string so then the if statement doesnt work like this.
it should be
int(value)
in the if statement.
I updated the step by step guide on the web so I hope this works now for you!
