motor 4 port does not work
ndawgpro
Post by ndawgpro »
m4 does work on any other port the you solder it on to but the m4 port does not seem to work as of now i have m2 and m4 together in the m2 spot
victorycube
Re: motor 4 port does not work
Post by victorycube »
Is this a viable solution? Seems like it could cause problems down the road if you need to have different rpm or whatever for m2 or m4
This does not work as the stabilization wound work. The Crazyflie might take of but wont stay in the air for long.
