We have been using the 'DEBUG_PRINT' to do some high level debuging on our firmware changes lately. It works well inside the cfclient. How can we grab the 'DEBUG_PRINT' output in Python (outside of cfclient)? Is there a logparam for that? If yes, what and where is it documented?
Thank you for your support,
David.
DEBUG_PRINT in Python
Re: DEBUG_PRINT in Python
You can setup a callback to get the console string while connected to a Crazyflie. This is done here in the client for example: https://github.com/bitcraze/crazyflie-c ... Tab.py#L71
In a script it would look like something like "cf.console.receivedChar.add_callback(callback_function)".
dastonge
Hi Arnaud,
We got there already and tried it without luck. A basic functionnal example would be great.
The best is always to add what you tried and what did not work in your question, it would have saved at least a round trip here
I modified the ramp.py example to add console printing to it, the change is as follow:
The key was to add the callback setup before connection, not after, otherwise I was not getting the startup console message (they where likely already transferred during the connection process).
For reference, the full example now looks like this:
diff --git a/examples/ramp.py b/examples/ramp.py
index d5d9808..ec36f98 100644
--- a/examples/ramp.py
+++ b/examples/ramp.py
@@ -50,11 +50,15 @@ class MotorRampExample:
self._cf.disconnected.add_callback(self._disconnected)
self._cf.connection_failed.add_callback(self._connection_failed)
self._cf.connection_lost.add_callback(self._connection_lost)
+ self._cf.console.receivedChar.add_callback(self._console_incoming)
self._cf.open_link(link_uri)
print('Connecting to %s' % link_uri)
+ def _console_incoming(self, console_text):
+ print(console_text, end='')
""" This callback is called form the Crazyflie API when a Crazyflie
has been connected and the TOCs have been downloaded."""
# -*- coding: utf-8 -*-
# || ____ _ __
# +------+ / __ )(_) /_______________ _____ ___
# | 0xBC | / __ / / __/ ___/ ___/ __ `/_ / / _ \
# +------+ / /_/ / / /_/ /__/ / / /_/ / / /_/ __/
# || || /_____/_/\__/\___/_/ \__,_/ /___/\___/
# Copyright (C) 2014 Bitcraze AB
# Crazyflie Nano Quadcopter Client
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
# MA 02110-1301, USA.
Simple example that connects to the first Crazyflie found, ramps up/down
the motors and disconnects.
import logging
import time
from threading import Thread
import cflib
"""Example that connects to a Crazyflie and ramps the motors up/down and
the disconnects"""
def __init__(self, link_uri):
""" Initialize and run the example with the specified link_uri """
self._cf = Crazyflie(rw_cache='./cache')
self._cf.connected.add_callback(self._connected)
# Start a separate thread to do the motor test.
# Do not hijack the calling thread!
Thread(target=self._ramp_motors).start()
def _connection_failed(self, link_uri, msg):
"""Callback when connection initial connection fails (i.e no Crazyflie
at the specified address)"""
print('Connection to %s failed: %s' % (link_uri, msg))
def _connection_lost(self, link_uri, msg):
"""Callback when disconnected after a connection has been made (i.e
Crazyflie moves out of range)"""
print('Connection to %s lost: %s' % (link_uri, msg))
def _disconnected(self, link_uri):
"""Callback when the Crazyflie is disconnected (called in all cases)"""
print('Disconnected from %s' % link_uri)
def _ramp_motors(self):
thrust_mult = 1
thrust_step = 500
thrust = 20000
pitch = 0
roll = 0
yawrate = 0
# Unlock startup thrust protection
self._cf.commander.send_setpoint(0, 0, 0, 0)
while thrust >= 20000:
self._cf.commander.send_setpoint(roll, pitch, yawrate, thrust)
time.sleep(0.1)
if thrust >= 25000:
thrust_mult = -1
thrust += thrust_step * thrust_mult
time.sleep(0.1)
self._cf.close_link()
if __name__ == '__main__':
# Scan for Crazyflies and use the first one found
print('Scanning interfaces for Crazyflies...')
print('Crazyflies found:')
for i in available:
print(i[0])
if len(available) > 0:
le = MotorRampExample(available[0][0])
else:
print('No Crazyflies found, cannot run example')
dastonge
Thank you!
So it looks like our main issues were:
- not connecting the callback before creating the link
- sending too much debug data (high frequency)
Thank you for your support.
