I want to hear your opinion for the possibilities of adopting the DWM3000 module for the loco positioning system.
I'm a CTO of Japan-based drone company, we mainly develop the system with drone for the customer.
Some of our customers recently try to use UWB module as an indoor positioning solution but DWM1000 is not acceptable because of the regulation in Japan.
Decawave is going to release the DWM3000 which comply with DWM1000 and it's also legal solution in Japan.
https://decaforum.decawave.com/t/new-dw ... lease/7402
I'm supporting the other drone supplier team to adopt their IPS with Japanese low and their IPS module also uses DWM1000.
They confirmed their module could accept DWM3000 instead of DWM1000 so I think it would be acceptable with your module.
If we use DWM3000 based module in Japan, we need to get the certification called Telec but we will be able to handle this.
Could you take it consideration that you will release DWM3000-ver loco positioning system?
We can share the cost for it.
Btw, I'm also love crazyflie and enjoy the simple light show using VIVE base station with employee's children. I think if we could use LPS, the space will be bigger so looking forward enjoying it in our country
